bent driveshaft fix
Just4Fun
First World Problems...
Southern Oregon
I have a Yamaha Sj style driveshaft that is slightly bent from removing a prop. Has anyone ever had any luck straightening one of these or do you just hang them on the wall of shame?
JM had one straightened for me through his machine shop, it was a JM heavy duty one. Shaft was only .012" runout though. Maybe ask Chris what he would charge. I think it was like $17.00 shipped each way to Florida.
Just4Fun
Southern Oregon
Use more heat next time you remove an impeller dude! I cant even imagine how you bent it removing the impeller.
Heat is why my driveshaft bent I had a 6' cheater on it wouldn't budge. Oxy/act rose bud for like 30 seconds and bent the shaft because I didn't have the housing clamped properly.. I didn't build the pump the first time.
I used grease when I reassembled with my new shaft, just took the impellar back off with a open end wrench no cheater bar..
Tyler Zane
Open Your Eyes
Heat the center of the (where the threads are) impeller not the shaft. If the shaft gets saturated with heat it works against you. A rose bud is a bit overkill and makes it hard to control where the heat stays. I hold the impeller tool with a box wrench and put an impact on the spline tool. The impact will be in counter clockwise rotation.
