- Charlotte, NC
So apparently this is the first 701 quick steer to break according to Dave. The weld that holds the steering tube to the hood mount broke causing the whole thing to push down on to the hood and also breaking the steering cable. I couldn't pull the steering back up through the strap that secures the tube so I know it was tight. I ride half surf half lake on my rockered blaster. North Carolina surf isn't too big and I'm sure there are dudes going way bigger than me with this setup. Looks to me like the weld that holds the steering tube to the hood mount was insufficient but Dave said he's never seen this before. I already had my guy weld it up and made 2 passes so it should be solid now. Also went ahead and did a b2 cable mod while I was at it. Has anybody else had this issue?
