Y
yamaslut
the faster a fluid (anything that flows) is going the lower the pressure it is at. so the water flowing by the cooling line should be at a lower pressure than the cooling line, because its moving faster than the air in the line. but then again i can see how it could happen because we are comparing liquids to gasses.
exactly... and should suck the water out of the lines....
he's confusing the fact that the impeller is creating pressure when spining, while the flow of water through a pump w/ out pressure from the impeller
would be at a much lower pressure, like you said, much lower than the coooing lines and sucking the water out of the lines...
I may be wrong, but I spent 3 years in the navy working w/ pumps, steam turbines and I know a little bit about how water flows
