Zero Client
BeerrroooOOOT!!!
- Douglasville, GA
I believe the engine in my 1996 SJ is all original. Its has got good compression thus far but am seriously thinking of doing a top-end to freshen it up. The cyl walls have slight scratches and theres a small area of aluminum piston deposits on one of the jug walls. The piston tops look fine - though a little lean for me. Images are before I changed jets by +5.
Images attached. First pic shows some aluminum on the cyl wall. Only one jug is like this.
Stock Bore/Stroke is 81/68, and would like to bring it to 82/68 which would make it 718cc. I'm not looking for anything really major as I'm still basically learning this ski which is currently way to fast for my ability. You could say I'm looknig for the best-easiest least expensive way out hopefully without having to resleeve cyls, modify block, change heads, or change out carbs. I'd buy some Pro-X pistons and gasket kits to suite and then get the cyls bored to accomodate the pistons. Can the stock sleeves and block handle this? What about my ADA Girdled head?
Thank you
