KTM434
Jamie FN Hickey
- Palm Coast FL
You have to consider a stock Yamaha engine has 155psi compression.  Do you know anyone running a stroker with that low of compression?  Side loading is influenced by rod length/angle and compression as well as stroke.  Most people running a stroker have huge mag pumps, total loss, high enough compression for race gas/av gas and ride harder than someone with a stock 650/701.  If you ran a stroker with 165psi and stock pump it would last longer.  Not necessarily the same as a stock 650/701 but it would be a lot more comparable.
