DaUpJetSkier
I like square
- Marquette, MI
What does everyone use for fuel line, I gotta do two full SJ's and would pref like a color and something that will last a while. Is 1/4" ID and 3/8" OD the size to get.
john from JSS told me tygon was about the best you could use (outside of OEM) and to expect about a 3 year lifespan....
not bad....
what fuel filters are you running in that pic above?
I use eBay blue and eBay green lines.
1/4 inch.
question, why do people coil up extra fuel line for the oneway valve?
The blue line I got from LP (Paul) is holding up good. Those fuel filters do get a little soft though.
I use 3/16 ID tube Tygon fuel line from McMaster Carr #5552K24
Mark44 Brap!
mark you really should start a mcmaster carr thread.
as it seem's like you get all the small and common parts that break or need replacing from them. it would be helpfull to quite a few ppl.
if your up to it
grif's two cents:biggthumpup:
if your up to it
