Idok
F1pro
- Nations oldest muthaF+++kin city
i'd still play with it....every so often I get the itch to see if the mag is better....so, couple months on..couple months off....
Rode it on friday with the mag pump again and it felt pretty good considering I haven't ridden in a couple months. I got the right bearing installed now and the impeller spaced tight to the stator vanes so it felt much tighter this time.
Some will say it still has too much traction but I have figured out how to shift my weight to make it slide at will so I figure its the best of both worlds now. It just takes some muscle where Scotts slides out effortless. I find myself overpowering Scotts now and can't keep it hooked up.
Hopefully I can get some more ride time in on it in the next feew weeks amd clear out some cobwebs.
Dang Boyer,you still running that antique!? lol
Wat?????
You are the ONE SINGLE guy on this entire forum that I was convinced was going to own only one aftermarket hull ever and be buried with it.
Thanks for proving me wrong, thanks a lot. Welp, may as well get out of the sport now.
Did you ever ride it after chamfering the back of the hull to loosen it up?
