I'd go higher octane...91 at least. I think all you need to change is the pop-off springs. look at Group K's website, I think it talks about it there.
Looks like the r&d timing advance kit said to unscrew the high screw 1 turn, and low 1 1/4 turn. Got it all together and seems to run ok in shop, will water test next weekend...
thanks..
Yeah, the R&D instructions have me thinking now too, they said 1turn high, and 1 1/4 turn low; but was that from where they were set before I installed the Timing advance, or from an all the way in-position? hmm...
from the closed position. are you running duel carbs? i'd start with the low speed 1.0 turned from closed and the high speed 1/2 from closed. and adjust from there
Thats what I thought too... Just installed r and d timing advance kit on my stock 03 sxr, set low speed to 1 1/4 and high speed to 1. Took it to the lake yesterday, idled ok but give it any gas and it would die. Got it started again and then turn the chock on half way then and it ran great, so richened up the low and high speed until it ran good, Ended up at 2 3/4 out on low speed and 2 1/8 out on high speed. Runs like a champ now, timing advance made a surprisingly big difference in preformance across the board.
What is the 2.0n/s?
So with just the am filters nothing else I would have to rejet? Running 50:1 ratio klotz oil on 93 octane pump gas
