Hey peeps,
I pulled the pump off my Mod Hull after wrestling with the wall anchors they used to secure it, and noticed it has a stainless stator section. The wear ring is also stainless and is really thick maybe over 4mm. The bore measures 140mm, and the prop looks to be a custom pitch 13/18 from Skat. Anyone have any info on this thing, how it runs, and if I should go through the trouble of repairing it? It looks pretty beat up on the housings, but okay in the stator/ring.
My engine setup for now is a 62Tcase, DBP ported cylinders bored to 753/ stock intake mani, DBP Taper Bored 38mm carbs, Custom Girdled Head, FBP Mod Chamber, Triton Water Box, Protec grate, Protec plate, Aluminum Pump Shoe. Is this enough juice to run this kind of pump?
Thanks
Thanks
