- Colorado
Klotz r50 only the best.
lol...
No offense FPF.
But this road has been traveled, dug up, traveled again, and re-paved with speed bumps, DOT signs and orange cones.
A search might be in order.
BTW: I run straight gas. Oil is for wussies.
my bad. I guess i could have done that real quick. lol.
castor 927 is the best I've come across. wear is almost eliminated ....lol. however it plays real problems on gas power valves. i personally run Pennzoil premium plus and a bunch of billet motors in our crew are running wfo on it. not saying it's the best but it works.
Unless you're running a tweaked out high HP motor then running expensive synthetics are a waste of money. Unlike a 4 stroke where time and heat breaks down the oil, a two stroke burns up the oil along side the gas consumed so the oil lubricating your engine is always brand new. I run a limited engine setup and my last 2 motors easily have 500+ hrs before rebuilds, and that was using a 40:1 mix of TCW3 Walmart oil.
Maxima K2 for my SS900 PV engine, cause that's what Xscream told me to use.
