Update pics:
When installing starter, make sure there is no paint/corrosion on the top case starter mount or starter flange. Don't want to create any grounding resistance issues here.
Using threebond 1211 on the starter nose ensures no leaks to this critical area. I like to put a light cream on the cases and then a big ring on the starter nose area.
Tool the 1211
Blue loctite on starter bolts to prevent corrosion or loosening of ground cable. (top bolt receives stock ground cable.)
OCD starter install finished.
Factory Pipe mani custom wrench for the 2 top middle "who designed this part?" bolts
Installed with JM SS allen bolt kits
Looking sweet! Carbs almost finished...will be on the way.
Requested painted intake, but I think the silver looks good?
