Anybody ever run it?
If you have how does it work for freestyle/racing?
http://www.factorypipe.com/a_ecwi.php
i run a programable msd on my FX1 and i noticable difference in the mid range punch it also seems to pull through the rpm's better i don't think i will install one on my RN. i have a micro touch w/solenoid for sale if your interested.ECWI works very well, but the MSD is NOT the one to use. Most people use the Jetworks/Micro Touch versions. The typical MSD comes on too late to be of any benefit.
Kawi 750 limited with all screws closed - 165 psi, SXR carbs, timing advance and enhancer
Kawi 650 with all screws closed - PJS 700 cylinder, 170 psi, SXR carbs, advanced timing. This is in a 550 conversion ski with a 20 degree impeller.
