Super Jet Are SBT superjet motor mounts any good?
raytherace
Canadian Brapp Dealer
St-Ray Beach, QC
i tried those motor mount and the thread are not enough long and not good quality. i broke like 5 SBT mount in less than 3 week on a BOB, definately not a good product for me. Follow the advice of sir OCD !!
You get what you pay for.
Probably good mounts for a stock application for the recreational weekend rider. That's SBT's target customer base, after all.
Buy something more appropriate for what you intend to do.
ntrsspray
I do DUMB THINGS!!
jersey
The gp mounts go right in. Using less shims. Get a hold of JetManiac he has them for the best price
Thank you for the info. So are the GP 800 mounts make a little different than the stock super jet mounts? Just wondering why they are recommended over stock. I found a good price on some in good condition.
G
Couch mounts are like 3mm taller - some people including myself have had to elongate the engine bracket and mount holes to get the motor to sit lower and to allow fitment of shims for other axis of adjustment. No two hulls are alike.
Well worth whatever grinding needed to make it work!
JetManiac
Stoked
orlando
Are the GP 760 and 800 mounts a direct bolt in? Or do they have to be modded to fit?
The couch(GP style) mounts have a larger diameter rubber section and larger metal top plate. This means a larger surface area for the vulcanizing of the rubber to both the base and top plates. Therefore, mount should be stronger because of both the larger rubber section strength and larger surface areas to bond.
We have been using these mounts used from couchs in both our flat and surf skis without many/any problems. I surf flopped so hard i though i might have a concussion and mounts were fine.
Couch mounts have the small angle and the same mounting hole pattern, but they are a little taller. Correct fitment will depend on your ski and how much shimming was necessary with stock sj mounts.
If they are too tall for correct alignment in your ski, simply shift mount toward the outside of the ski and this will lower their effective height. Sometimes you will need to enlarge the holes on the mount base to allow more movement. Round file or dremel makes quick work in the soft aluminum, and you dont need to move them far.
I like to install mounts shifted outward with bolts just barely tight, install motor and then check alignment. I will carefully loosen and slide mounts in to raise motor close to final alignement. Then i tighten the mounts and only use a few thin shims for final alignment. You can also align motor in this way with no shims but it takes a little longer.
OCD Solutions
Rentz, GA
Changed out a couple today and snapped some pics.
Couch mounts, OEM and Cold Fusion side by side.
Here is one of the failed mounts. 1 was failed, another was close behind. This is the second set of oem mounts in my wifes ski and you know she isn't abusing them. She now has a full set of couch mounts.
Yami-Rider
TigerCraft FV-PRO
Texoma
Do you think the couch mounts are better/stronger then the Cold Fusion mounts?
OCD Solutions
Rentz, GA
I have no idea, I am waiting to fail a couch mount before I swap the cold fusion ones in. I almost stuck them in my wifes ski but it seemed like overkill for ber riding and it would not be a true test.
waterfreak
I had a vision!
s florida
the SBT motor mounts are complete garbage!!! I had 4 brand new ones and was able to split two of them with my bare hands!!WTF!!
I just called to return them back and told them to stop selling this crap!
