- Cleveland Ohio
If you ride it and the head is leaking, it's gonna blow....
If you ride it and compression is really that low in the one cylinder, its gonna blow...
If your tester is working properly, you either need new o-rings or you need to rebuild (at least top end). Don't wait until you take out your cylinder, cases, and crank, then it will cost you 5 times as much to fix. A top end is relatively cheap...
