SXR Bogging gremlin driving me nuts!
06 Sxr..Internal mods..Exhaust Stinger and A/F's.
Problem..Harder than normal starting, intermintent bog all through out the powerband. Will bog/sputter at wot for a few seconds then cleans up, the same has also happened when blipping from 1/4 throttle.
What I have done so far...Rebuilt carbs (3 times), replaced all fuel lines, drained gas tank, cleaned fuel pickup, replaced fuel filters, inspected reeds, new gas cap/o-ring and filler neck. I am running 50:1 and the plugs when inspected look fine. Compression is also good. Stock carb settings. Bog remains if I ride without the hood. No visable exhaust leaks. Visually I see nothing wrong.
Story....3 years ago I did have problem with water getting into my tank causing a horrible bog. I have had the problem since. My filler neck actually had stripped threads which was letting water into the tank while doing subs and fountains. Problem got better once I replaced the pieces, drained tank/lines and rebuilt carbs. Unfortunately the problem only got better and never fully went away.
What else should I look at? Im really thinking it is still a carb issue but I am no expert. Im very close to buying an extra set on carbs and swapping them to see if the problem goes away. Any input before I spend money that might not fix the problem?
Scorn800
Ride for life
North NJ
I would do what DJ says 1st. Cutting the spark wires back should work. You may also need to check fuel petcock (on/off/reserve switch). You may have debris in it causing carbs not to get full fuel pressure.
I will take a look at the carb return and one way vavle on the tank. I am pretty sure I have already looked over those but I will double check just in case. Kahuna, I havent actually replaced the stock jets. I just cleaned the stock jets to make sure they were clear of debris. Same with the N/S
Worn needles..never heard of that but since it is mentioned I will just replace the jets and n/s to rule out that problem ty for another idea..sooner or later I will find out whats wrong
It's very common.
There is no need to replace the jets. They don't wear.
djkorn1
kidkornfilms
Cleveland Ohio
Are carbs opening at the same time?...check to make sure linkage isn't broken and one carb is opening only part of the way.... just happened on mine again. (3rd time)
