F
Freestyleriverrat
66e is heavy
Lameys are heavier that OEM cylinders. I wish I had a bunch of motors laying around for weight comparisons. I know the 66e's crank is 10lbs heavier than a 701 crank. Complete motor wise I would say that the package is only about 15lbs heavier that a 701 based lamey.
if you have a light weight hull, add the 66e and magnum pump you will probably the weight of a stock superjet or just under that.
