Super Jet turns over without spark plugs only. WTf?
mademan9
I ride a SuperFrk WannaBe
Jonas, so sorry to see you are having issues, call me if you want help troubleshooting further.
Its not that big of a deal, I have been a little busy at home with a 4 month yr old. So my time gets a little occupied. But thanks I'll give you a call anyways , I'm interested in another part you sale!!
I think my problem is small, Im sure its something I'm missing
mademan9
So today I finally had time to fool with my ski. My Buddy al came by and I think we figured out what was wrong with my ski. First thing we were going to do was pour a little fuel in the spark plug holes to see if it would crank . While pulling the plugs we decided to check the spark. After a few test we think that is the problem . Not enough spark. It does spark a little but not as much as it should. Having a second person look helps a lot. so I'm guessing now that the coil is bad. I have a replacement oem so I will try that tomorrow.
mademan9
so here we go again. I changed the coil yesterday morning and once again nothing. NO spark. Well let me make myself clear. It had a faint spark when I leave one plug in and try the test. There is a little spark but not much. Today we tried taking the ebox apart and replacing a bunch of parts. I tried everything new in the ebox. I even tried a oem cdi and nothing . the same thing. So what is my next step? WOuld the stator be the problem? Im running a lighten 61x flywheel with a 650 stator from my old square.
WaveDemon
Not Dead - Notable Member
Hell, Florida
the only things that affect spark are: flywheel, stator, cdi, coil, spark plugs and all the wires that connect them. some of the parts are testable, swap known good parts until you find the culprit.
If spark is weak and intermittent I start with the cdi then stator
did you trim back the wires and reattach your plug wires? not sure if you have screw on or crimp on boots, but both styles wear out and can cause the symptoms you have desribed. I have had good luck with the msd crimp on boots.
mademan9
It's alive it's alive!!! The problem was the stator. It had a cut wire . Some how it looks like the flywheel sliced it. I replaced the stator today and push start and the magic happened. No priming at all. The ski didn't run away . It was very reasponsive to my throttle. So Friday I will put the ski in the water for the first time. Thanks everyone . I will keep you guys posted on the ride report.
mademan9
Glad you found your problem!
BTW add a JSS coil to your list for salt water reliability..
Already got'em! Thanks for help. The next thing I will be calling you about is the mag pump setup you sell. Ill try this oem with hooker for a few , then the mag must come. Ive been on cloud nine all morning thinking about riding my new JetManiac Motor!!
Buckwild12
I'm moved by DASA power!
Sweet glad you found out what was up! I'll let you know what the mag pump is like, Chris is putting it together for me this week!
