Ported 61x cases, ported 64x 760 cylinder, stock head and ignition, Riva Powerbomb carb. Currently at 130p 150m, 115 spring 2.5ns at 20psi popoff. Idle is nice and power seems good right off idle but after 1/2 throttle it struggles to buid RPMs. If I get a little air in the pump it will get past the hang in the revs and makes nice power, sometimes if I stay up in the higher Rs it will rev nicely to the top but if I keep the pump loaded it doesn't like to get past it. If I do a turn sub it will struggle to build RPMs but if I give it a little hop and unload the prop it takes off like a raped date. Most of the time it's just blehh then it will take off and brap nicely. I do not have access to a tach.
Also I had started with MattE's specs in the carb database (117.5p132.5m) and worked up from there to where I am at now.
I ended up putting in a 155 pilot and 155 main just for
s and giggles and it helped the problem. Still slow to respond when tooling around at slow speeds but when riding around in the midrange it is clean and revs quick to the top.
*update: I have swapped on an SBN 44 but still having issues, see post #23
