I don't put much stock into reading plugs.
Your plugs are a nice brown color, but it's far from running right.
TL will not happen, I may try and bump the compression but probably not anytime soon. I also have found the powerbombs easy to tune (on all but this engine) and am now seeing that it was likely not an issue with the PB in the first place. It honestly ran slightly better with the PB than it does with the 44 (when it was out of the funk). This exact setup actually ran very well in my REV hull, (better when I was back in MN on the flatwater than it did in the surf) which makes me think it could be a pump load issue?i think you should do what supertune told you to try some time ago, bump up the compression to 195-210 and run a TL with a good curve. this is how he said you need to run this frankenstien motor of yours. i have found my powerbombs to be so easy to tune as a single and duals, very forgiving.
I ported the cylinder myself but it is nothing more than a copy of the sport port template enlarged slightly for the 84mm bore. I only worked on the exhaust port and only widened it.It's possible that your porting is just crap and that is actually causing the problem. Although I'd exhaust all other avenues before ruling that and trying a different cylinder.
