I can understand not wanting to go total loss when you ride surf all the time. Plus total loss and a high compression head would easily cost about $1000 used and closer to $2000 new together. I would think if yamanube could afford that, he wouldn't be running the frankenstein motor that he is.
I've got a 135 main jet I'll send you if you want to try it but that seems excessively small compared to what you're running. Surely someone in that crew down there could hook you up with a handful of jets to try. Takes 5 minutes to swap jets on the beach and you'll instantly know if it made it better or worse. I can't see pulling the intake grate helping any. If the prop was too big, it wouldn't be snappy off the bottom.
