- Atlanta, GA
I have a 91 superjet with a 701 / 61x and I have read a bunch of threads about why my pipe would be getting so hot.
I was able to blow through all the lines easily so it doesn't seem clogged.
I never had an issue until I put a Pro-tech head on. I torqued the head down following the manufacture's instructions and even checked after about 25 minutes to make sure the bolts were still torqued down enough.
The only difference in the setup of the cooling lines is that the stock head was tapped on the top of the head and not the side. (In the picture on the left side)
Something I did try:
It didn't look like there was enough water flowing from the left side of the head to the top of the b-pipe so I capped the line coming from the right side of the head and more water made it to the end of the pipe (stinger) but it still got way to hot.
Any ideas what's going on? Here's a pic of my setup. Trying to get a few more rides in before it gets to cold. any help would be appreciated! Thanks
