Dont know if some of you remember I put a post about the prob's I was having with my ski,
basically its a completley standard blaster 701, when I go out after about 5 mins or so it drops on to the front cyclinder and wont rev out above around 2500 rpm, if you are lucky sometimes you can feather the throttle and it wil clear and run flat out again, other times it makes no differance and its back to the beach.
Put it back on the trailer, give it a few minuites, fire it up and it will rev crisp as anything. like theres no problem, so put it back in the water go out and low and behold, after 5 mins of hacking around its back on to one cyclinder again, so its back to the beach, back on to the trailer, and home throwing my toys and dummie out as I go :banghead: :banghead: :banghead: :17: :17: :17:
Ive run out of ideas as to what it could be and am really hoping that someone can point me in the right direction as the seas gona get really cold soon, so Ive only got a few months of good riding..
things done to it so far to try and cure the problem include.
Full rebuild inc; new pistons, new bearings, new rings, all new gaskets, new seals, new fuel filter etc
new CDI
new stator
new coil
new plugs x9millon
new HT leads
heat sensor dissconneted (made no differnace)
handle bar switch dissconnected, striped cleaned and rebuilt
carb stripped and rebuilt x 6
lots of swearing
blessing with holy water
the threat of being taken to deep water and sunk
All of the above had made on differance and the problem continues, so has anybody got any ideas as to what it could be, Im going round the bend and I really just want it to work..
cheers in advance
Alex
new CDI
new stator
new coil
new plugs x9millon
new HT leads
lots of swearing
cheers in advance
Alex
