Surfriding Yamaha stator plate alignment
I thought the plate had a mark on it to know where to set it? So I guess my question is where Do I set the plate or how do I know where to set it? I can upload a picture soon
Thanks in advance
IS0LD0UT
I hate winter
MN
hopefully someone else can jump in with more experience than me. The couple I have done had marks
#ZERO
Beach Bum
Florida - U.S.A.
It appears you have an aftermarket stator and cases so it doesn't have the alignment mark tabs.
Here are couple pictures of a normal 61X & 62T stator with the timing advanced two or three degrees.
SUPERJET-113
GASKETS FOR CHAMP BRAP!
Ya, you can see that that the OP's stator will only go on one way. It has that boss sticking out of the cases and the indentation on the stator accept it. So there is no way to mess it up, and if you want to adjust timing just grind off top of that spot on the cases, but mark somewhere on the stator/cases so you still can reference where OEM timing is.
