Ericfox
Do it twice?That's DooDoo
- Akron area --> OHIO!
got the xft scupper and went to the hardware store figuring I would get some 3" pvc to make the hole... well I didnt think about the pipe size being 3" id and the scupper is 3" od...
The pvc od is like 3.5 inches.... so I dont think that is a good idea to use it....
Who has installed the xft scupper? What size pipe did you use to install it? Did you just use the pipe that came with the scupper to drill the hole through the foam?
Thanks.
Thanks.
