XFT Carbon Trim
Just Wanted to give a shout out to Sergio Bueno at XFT for making the best trim system available for the superjet. Not only is this system VERY light (all Carbon Fiber) but it throws VERY high. It will max out steering capabilities on both sides as well if you use it with his steering cable. The trim creates a monster wake and it is a must for flatwater flips.
Nozzle comes with interchangeable ring system that allow you to use from 83mm to 86mm bore nozzle.
Complete kit compound by Carbon Fiber Nozzle, Carbon Fiber Steering Nozzle, Carbon Fiber Ring, Racquet, adaptor, Trim cable, lever, tube and glue.
$790 USD
www.xftonline.com
Pics below
Considering it is complete and ready for freestyle I don't think it is too expensive.
I did see it last week (a friend of me got it)... the part is awesome. The cable and lever mechanism are top notch.
Gera
marshb
90's model
ann arbor, mi
This piece is INSANE!! I have seen many trim setups, and this easily double the throw of any other trim. It blows your mind when you first see it. The amount of throw is almost unreal, makes backflips on a limited ski with light hull *possible* at least 3/4 flips with little practice.
Will be ordering mine up in a few weeks.
**EDIT** Marshj wrote this post...MarshB is my lil bro
