Ok guys Im new to an x2. Ive been wanting to purchase one for awhile. So I found one over the weekend that has been on a stand in a guys garage for 5-6 years without starting. The story is that the carb started to act up and he personlly wasnt cracy about the x2. Said it was hard for him to ride and he never really got the hang of it. So instead of fixing it he just put it on a stand and bought a new ski. He had the intentions of fixing it one day, but like many of us life got to busy.
So I have it home now and I dont want to just throw a hot battery to it and hit the starter. What i've done so far is pull the plugs out of it and poured a little mystery oil down the cylinders, also poured some mystery oil into the crank case via the oil filler plug on the crank case. I plan to let it soak for a day or two and then turn the engine by hand with the plugs out. What else should I do before attemping to start it? Is there anything I should do to the pump, any lubricating to be done on it, maintenance that I can do prior to starting? Also why does the crank case have an oil fill plug? Its a two stroke? And should I take my mix gas and pour straight into the crank case? The motor is not locked up but it has been sitting for quite awhile. So I know its dry. Honestly I'm not familiar with skis at all, this is my first one. So not sure where to go from here. Any help will be great. FYI it is a 1990 x2 with a bunch of aftermarket parts. I will tell you what they are once I can identify whats what.
Thanks JBM
Thanks JBM
