WTB 66e GP800 Laydown pipe & standup intake manifold
Looking for a 66e GP800 PV motor laydown exhaust manifold. I do not require the expansion chamber.
Also looking for a standup conversion intake manifold for the 66e GP800 PV motor as well.
Trying to gauge prices on these parts prior to sourcing the WB1 for the conversion.
I'm thinking about doing a similar build on my WB1. Following. Good luck, would love to connect if you get it complete. A friend of mine said Jeff at Waterdawg Kustomz successfully put an 800 with a laydown pipe in his WB1 and it was a blast.
Yeah, he said he’d still sell them and has a couple ready to ship but, it’s not worth $1,550 for the laydown pipe and $550 for the standup carb conversion that he’s currently asking.
Would much rather build a 701/760 at that price and have a much more supported platform.
66e GP800 motor is just a passion project for me and I’ve had the motor on the shelf for over a year now. Would much rather wait and save some funds buying used/potentially making my own.
Have already sourced the Riva rave valves, done the group K modification to the bottom end so random crank seal leak no longer occurs, VForce 2’s, WDK motor mount kit, gotten a WDK cylinder head that had a girdle kit (somehow found this on eBay cheap) and got the PFP expansion chamber.
Really only missing the laydown manifold and upright carb conversion and it’s done.
Just finished the GP1200R build so got a good bit before I get bored of that and actually finish the 66e 800 WB1.
I always wanted to do an 800 with two GP1300 NPV cylinders to se how it would run
I’ll leave these here…
The illusive Oside Plugs for the 800/1200/1300 PV motors (found while digging through Oside’s old archives)
As long as you can source the Riva rave valves and do the Group K crank seal fix the 800 motor is pretty reliable.
The case defect causing the crank seals to leak didn’t help for it or the PV engines reputation at all but, with the Group K modifications and rave valves these motors put out some amazing power for the money.
The only real hurdle to putting the 800 into a WB1 is the, in my opinion, overpriced WDK parts.
  • Plug%20gas%20valve.pdf
  • Plug%20gas%20valve%20w-oring.pdf
This was posted by Harry Klem from Group K in December of 2020 in a Facebook Group
A very important issue to all GP800 and GPR1200/1300 Owners
At Group K, we continue to work on “only” 2-stroke pwc engine platforms…. And we do a lot of them. Anytime we assemble an engine in-house, it is standard procedure for us to “pressure test” the assembled engine to assure there are no air leaks. Doing this pressure test assures that there are no air-leaks (that can result in difficult starting, erratic idling, and random lean conditions that can easily deliver a seized piston when operated at high rpm).
Over the years, we have seen the GP800 and GPR1200 engines be particularly susceptible to developing air leaks at the rear crank seals. What makes this disconcerting is that both of these engines have two rear crank seals, and failing both rear crank seals to result in an airleak “should be” very uncommon …. But it’s not.
We recently assembled a freshly rebuilt GPR1200 motor for a customer, and when we pressure tested it, It had a “huge” visible airleak at the ID of the brand new real crank seal we installed ….. and we realized that both of the new crank-seals we had installed had to be leaking in the same grandiose way …. And that is just not supposed to happen.
With that, we removed the bottom case of the assembled engine to find the source of the air leak. To help understand what was happening, we then re-assembled the engine with only the inner rear crank seal in place to we could see the source of it’s leak. What we saw was something between frightening and humbling.
As we pressurized the motor with only one rear crank seal installed, we saw that air was leaking out of the engine faster than we could put air in. We quickly realized that a “cast-in” oil galley in the top case (meant to bring oil in between the two rear seals) was completely bypassing the inner rear crank seal …. Thus making this inner-rear crank seal 100% useless and without purpose. This meant that the single-spring outer crank seal next to the drive coupler was the only seal offing any sealing properties at all for this engine. It bears noting that ALL valved GP800 and GPR1200/1300 engines have exactly this same defective feature.
The only solution for this problem was to fill the offending galley with a high quality epoxy, and then dress the hardened epoxy down to match the machined seal holding surface of the case … and we do so.
Afterwards, we once again pressure tested the engine with only the “inner rear” crank seal …. Instead of leaking air out faster than we could put it in, the engine held 8+psi perfectly.. problem solved. Obviously, the outer crank seal would now just be a failsafe luxury. We applied a generous amount of dielectric grease between the two rear seals before final assembly (as we have done with 440/550 jetski engines for decades) … and it was all good.
Afterwards, we reflected back on the countless GP800/1200/1300 engines over the last 22 years, that we had worked with that had experienced “random” rear cylinder failures for no apparent reason…….. and found ourselves at a lack for words why we had never noticed this defect earlier….. sorry about that.
The good news is that none of the earlier “un-valved Yamaha 633-1200 engines share this same defect.
The easiest method for filling with Epoxy was discovered by Christian Morris.
When filling the second hole for the rear seal in crankcase, I have found tapping it first to be the best route to go to provide mechanical interference for the epoxy to bite into
This is the first I have heard about a case defect, please elaborate or point me in the right direction.
^ woops forgot to click reply here's the full writeup from Harry Klem at Group K
This defect is on all 800/1200 PV cases. (Can't confirm 1300 PV or not but, likely has the same defect)
Have personally seen the defect on both 800 PV engines I have and both 1200 PV engines I have.
XScream does epoxy this defect.
Thanks for the info , I am about to build three 1200's and an 800 soon most are for flip skis and one for a customer.
Myself
manic mechanic
Twin Lakes AR
BWaaaHaaaaaHaaa.....I've rebuilt a few handfuls of the 800/1200/1300 engines and noticed this completely on my own. I just gouge it up with a pick tool and fill with "Pro-Poxy". I was actually looking for WHERE the oil comes into the bearing and saw this. The reason I was looking is because on the 65U NON powervalve 1200, the oiling hole actually needs elongated to get oil out instead of just running into the back of the bearing race.
I have been into a slew of 800's and 1200's but usually just top end repairs , I think I may have built one complete 800 and one 1200 over the years , I guess I am about to make up for all of that this year lol.
I just talked to Jeff about his 800 b1 set up this week when I was down there. He said he just used the stock exhaust but it was a huge pain because he had to cut the hill and build in a little bubble to make the exhaust fit. Like [mention]rubbeerducky [/mention] and I had been talking about the 800 would definitely have a higher ceiling than the 760 but it would be way easier and most cost effective to just run the 760
Yep that was the problem with the 800 , the conversion parts needed to run it were always way too high.
