I need help.....I got a set of wsm pistons for a top end on my engine. This is stock bore size as I got a new oem cylinders. When looking at the bottom of the old piston and the new, the old one has more material cut out on one side than the wsm new pistons (see pic). Is this ok ??
Also it says to install the C-clips in the "up" position?? I dont know bc all I got was 2 small wire rings, how do I make sure they are facing up??Does this matter??
How do you get them in and the old ones out?? They are in there pretty tight!!!!
And lastly, What is easier, installing the pistons thru the top and then connecting everything up from the bottom or installing the pistons on the rods/bottom end first and then putting them in from the bottom one at a time??
thanks guys, this is my first engine job.
