Get some marine sta-bil and measure appropriately for your gas levels and use a fogging spray like yamalube fogging spray in the carbs at a medium idle. Doing this on a trailer backed into the water works great so you can run it the full recommended time and keep your power plant from overheating. if not you'll have to do it a few times on the trailer. Make sure you don't go too long and then give time for the motor to cool then repeat one to two more times. Once your exhaust is thick smoke and you are spraying it and it chokes out your good. I've done both and I'm in Michigan and every year my motors are great to go.
