Will a rickter float ?
Penrith
After all this talk of sinking skis has any 1 sank a rickter before do they float they have no nose foam no room for it not sure what foam is in the tray area either I didn't realy want to do a myth busters experement but maybe I will if know 1 can help I'll sink that mofo for fun in my dam at the compound muddy brown water is good for the inturnls right . Maybe tc freeride has sunk a rickter maybe not any idea
OCD Solutions
Rentz, GA
We talked about doing a sink test on my Matrix but i couldn't bring myself to do it. I did manage to get the stock SJ nose foam in the nose though, I don't see why you couldn't fit it into the Rickter as well.
Yea I was thinking about it do since Chic's sinking thread... I was wondering if my stock hull would float. I don't think the foam is in the nose. And I know there is'nt any nose foam in my wammer hull
hey mate,
they do float eventually they don't come back up real quick though so hold on and they don't tow real well either, have a tendancy to turn upside down and submarine. any joy with ya motor?
Matty
stanton
High on jetskis.
atascadero,ca
scupper = less volume for foam in the tray
scupper = more seals that could leak waterlogging the foam
when a ski is upside down, the air pressure in the engine compartment keeps water from just pouring in. if that pressure is not there due to a scupper your boat will take on water much faster.
Dustin Mustangs
uʍop ǝpıs dn
Holland, MI
If you are wondering if a certain ski will float or not, you should just assume it is already 100% filled with water (worst case scenario). So how fast water can get in shouldn't even be considered, it's already in there.
im in the midst of reinforcement on mine and the space up in the nose is TIGHT
I dont thinik a roundie nosefoam will fit past the pole bracket area........im going to cram a pool noodle up in there
the fuel filler should help with the scupper issues..
