Will 760 fit in 93 square
with the oem pipe you will be better off with the 6m6 motor
buy a pipe or waste lots of riding time and perf.
oem 62t man will bolt on but will not work with a stock sj pipe
i think most peeps thought that you already had a exhaust system!
a good factory b pipe is the best investment for a sj and should almost be 1st!
ok found the intkae and all that ********, and now i have also found the exhaust what do i need for that. do i just need the manifold and the bracket or do i need he big black chamber as well?
A pipe doesn't go on cases - I am not sure why you are asking about cases?
You need a pipe for a Superjet. The manifold will need to be for 62T cylinders OR (better) you need to put either inserts into the exhaust bolts holes in the cylinder or drill the holes in the manifold larger.
I think it's been described in more detail in earlier posts in this thread.
yes i know this that ineed 62t or better manifold, but will the rest of the pipe line up just fine and the bracket that holds the chamber work jsut fine? Also do i need get the rest of a 701 or w/e exhaust or do i need just the manifold and mounting bracket? Sorry thats what i was tryin to get at.
Is this a stock exhaust?
For aftermarket exhausts, any system made for a Superjet will fit except for the manifold.
STOCK exhaust of any kind with 760 motor and a sj will not work!
you MUST have aftermarket exhaust to use the 760 motor in a sj
your stock exhaust will not work with the 760 even if you bolted it up you would be wasting the 760 motor
would i be wasting the power of the motor? is that what your tryin to say. All im askin is if it will work to make the boat run? Yes this is a stock exhaust.
