Wich one of these shaft holder work on superjet?
thats what goes in the impeller to put the new one on and tighten it
so i need both tools then, the shaft holder and the impeller tool? but why would i need the impeller tool i can just hold the shaft with the shaft hold and tighten the impeller by hand the best i can and that should be good enough since the impeller tightens itself everytime you ride, there is no way it would get loose unless you had reverse on your jet...
michael950
for me to POOP on!
Houston, TX
You have to hold the shaft to remove the impeller, thus the shaft tool.
You have to have the impeller tool to remove the impeller. Only a stock impeller does not require an impeller tool. This is a good thing.
Different impellers require different impeller tools.
