Hey yea jsut bought a 760 from someone on this site and i was told that it will just drop right into a 93 sj. well just went to put in to boat and the intakes are not even close to lining upright or even right angle. Whats up with this? Are we missing something or what?
We should be guessing you did you not get carbs with the motor?
You will need either:
a 62t single carb intake $160 + carb cost (or can use your 650 carb)
A stock dual 38's setup (about $100 complete)
a stock 760 carb setup-dual 44's ($250 complete)
an aftermarket set of carbs and aftermarket intake ($lots)
As for the pipe, you can either get the timecerts to make the bolt holes smaller, or drill to open up bolt holes on exhaust manifold.
Edit: the seller did not really
lie to you, it is a straight drop in to your ski......He could have mentioned the carbs though....
