- Ocala, FL
Im replacing the bearing and seals in my midshaft as part of the 140mm pump conversion.
I didnt pay any attention when removing the stock seals but i have 3 new 20x52x7 seals with SS garter springs read to be put in (i was told i needed two, one for each side but ordered an extra. It looks like i can fit two on each so I may order a 4th and do that)
So which way should i put the seals in? I googled a bit and read that the direction is important and that the spring should be on the side the is containing whatever. So im in containing the grease from coming out by putting the springs facing the bearing or am I keeping the water from coming in by having the springs face outward. Or possible one of each??
