112motorsports
CLETUS
I know that this question has been address in several othre posts but after searching for 2 hours now I can't seem to find the post that showed where to cut. I have seen the hole cut out up at the front of the tray but my question is how do you access the inserts on the top of the pump that hold the pump in, I have heard these leak and need to be glassed over or covered with 5200. As well as adding reinforcemnet to the side without the entire side being removed? How do you put the try back together? Just glass the piceses you cut out back in? Also would just cunnting the whole tray out front the top of the rail caps down the front and to the back so you are removing the whole tray work? Any insight and PICTURES would be greatly appreciated. I am getting ready to mangle my ski this weekend and was looking for some direction before cutting it to a million pieces. Thanks for any and all help.
