infamy
Westside Freeride
so my ski revs up on the stand but when i put it in the water it wont. in the water it runs but wont even plane out just goes a couple mph and is real boggy and dies if you give it alot of gas. on the stand when you rev it, it sounds like it has a littl airleak cause it keeps running for a few seconds after you let off the gas. i checked any visible gaskets/seal/hoses but havent found the culprit. any ideas? what are common sources of airleaks? is it possible this could be an electrical problem?
heres what im running - 760, b pipe, ada head, dual 44s with dual pickups, msd enhancer.
