the WaTeRhAwK
fryin' up a/m electrics..
- okc
Yes. "Saber" is the 100:1 premix version. Neither of which are suitable for breaking in an engine, as they will only allow the rings to "polish" the bore, and not cut into it.
You're saying the rings won't seat. I've seen the do just that on my own engine.
Matt, have you ever heard of street racers throwing Ajax or Comet brand cleaners into their carb intakes in order to seat their piston rings?
The thing is, Your engine will have compression regardless, but if you broke it in with full synthetic oil, it most likely still needs to be broken in, let alone if not have a hone put through it,depending on how many hours you've put it through, the surface broken, and ash oil to allow the rings to properly seat. When you seal off the surface of the bore by polishing it, you have to break it again so the rings will have something to drop into. Best case scenario with an engine treated like that is Yes, you will have "compression", and yes the rings will eventually "seat" but they will be seated against a polished bore, will not perform as well as a well seated top end, and you will need to rebuild the top end a lot sooner because of the a mirror finish on the cylinder walls, regardless of whether after break-in, you run full synth or not.
So, what exactly indicated to you that your rings seated? Just because your compression came up?
Just curious.
I am just Curious Travis can you explain how the compression went up without the rings seating in, I can't wait to hear this one.
So out of curiosity...how would one be able to tell one topend, broken in on non-synthetic oil, apart from another, broken in on synthetic oil?
The compression will come up regardless, and most likely not to the point it should be, just from heat cycles alone. That doesn't mean the rings are "cutting" into the bore like they're supposed to in order to properly and evenly seat. The problem is the rings will not evenly cut into the bore like they're supposed to, they will sit against a "polished" bore, and the top end will not last as long before needing a rebuild, because the surface of the cylinder has been closed off with a glaze before the rings could cut into the surface. Also, the overall performance of the engine will suffer compared to one broken in properly.
As long as some of you guys have been doing this stuff, I can't believe you actually have to be told, TERRY!!!
lol
