I read this as I'm stuck between a headake and a mag pump. Here's how I think about it. Ignition can make you more power. More power = more likely things break. The mag will better use the power you have and as long as the bearings are pressed correctly it's not going to blow up anything. Ps: hx3's are awesome.So for me I'm stuck between ignition or mag pump. I'm just curious why there aren't more people using hx3s.
Good point. I'm not as worried about things breaking as I am about the best bang for your buck. My timing curve will be fairly mild.I read this as I'm stuck between a headake and a mag pump. Here's how I think about it. Ignition can make you more power. More power = more likely things break. The mag will better use the power you have and as long as the bearings are pressed correctly it's not going to blow up anything. Ps: hx3's are awesome.
Dont see him pushing a 148 with a 61x with porting.If your going mag get a bigger pump then 144 you Can use it when you wante Big power.
The HX3 is awesome, and it doesn't break parts as long as your ignition system is solid. I have one on 2 skis and it is a huge upgrade IMO.I read this as I'm stuck between a headake and a mag pump. Here's how I think about it. Ignition can make you more power. More power = more likely things break. The mag will better use the power you have and as long as the bearings are pressed correctly it's not going to blow up anything. Ps: hx3's are awesome.
