- Mn
Best is to store it in a ski and ride it every now and then
Sent from my iPhone using Tapatalk Pro
Fog Motor. lube outside with and wrap up in plastic......................... seal up all the intake, exhaust, water line fittings plug holes etc etc
Lube outside with?
so? put it in your snowmobile then.Hard when there is ice on the lake....
Spray fogging oil in each spark plug hole or through exhaust oulets if no mani installed on it, then turn over motor by hand to lube cylinder walls and rings well.
Spray fogging oil through intake area and lube crank bearings and parts, then turn over again. Then tape off intake and exhaust and spark plug holes. We sell red push in plugs for plug holes.
Use protectant spray (we prefer CorrosionX) and wipe on exposed metal parts.
Then use plastic bag over motor and remove as much as air as possible and close.
