What happened to PWCtoday?
SuperJETT
none
I agree with everyone else, your pc has the right IP address, but something between you and there is blocking you.
I know Bryan reads on here, so maybe he'll finally sign up and try to give some help or at least answer if he banned you.
Air Gramps
Air Gramps
Virginia Beach
It's your security environment.
I had the same problem last week with my website www.wavejunkies.com, I could not see it.
I did the pings, and traces. All looked fine just couldn't get to my site. I had to remove my COX security environment and all worked fine after that. This was a free security s/w from my cable company.
I still have not re-installed the POS software , cause I believe it caused other anomalies that I have not seen since uninstalling.
good luck.
WaveDemon
Not Dead - Notable Member
Hell, Florida
If you are banned it will say so. :27:
S
sunny_az
Guest
good luck.
Cox Software blows worse than just being bad, it is literally crashing OS's(the WinMe folks needed an upgrade, anyway).
You should count yourself lucky to not need a wipe.
WAB
salty nuts
coastal GA
SUPERJET-113 said:
Im missing out on parts whoring!!! :banghead: :banghead: :banghead: :boggled:
Man you missed out! Factory Pipe gave away 50 B pipes. We all got one. Sorry you missed out. :sgrin:
SUPERJET-113
GASKETS FOR CHAMP BRAP!
:biggrin: :biggrin:
Thanks guys/gals for all your help, I figured it out. As mentioned above, it was my firewall settings, something got changed in there. It was blocking my email from going out too. Got it all figured out. Oh and Bryan sent me a email helping me out too. Thanks Bryan!
:biggthumpup: :biggthumpup: :biggthumpup: :biggthumpup: :biggthumpup: :biggthumpup: :biggthumpup:
