Super Jet What did this pump come off of?
550headache
tobacco grower
tobacco valley
From what I understand superjet 144 pumps came with aluminum reduction nozzles. This one has a plastic one with veins and the stator section has the big hole filled from the factory. Did this come off a sj or something else?ImageUploadedByTapatalk1376048868.308854.jpg
JetManiac
Stoked
orlando
That looks like a vxr probably a provxr. SN sj had plastic reduction nozzles but without the bilge siphon fittings that yours has. The hole for stock siphon is closed because siphon hooks to nozzle instead. The driveshaft wont be right length for sj unless it has been changed out.
HB
'93 to '95 Squares also came with this style pump - with the old pressure dump siphon system off the stator unused (and thus undrilled) and the nozzle with the siphon provision.
550headache
tobacco grower
tobacco valley
driveshaft is right. came out of a sj. pulled it apart and checked bearings/regreased. why there isn't a grese fitting to fill between the t bearings is beyond me. I filled it the best I could but its not stuffed full. is this ok? hopfully my square will be back from paint sunday do I can start the rebuild!
