- Lafayette,LA
I have a 94 SN Superjet with the following mods Lightened flywheel, Milled head 175 psi, and a 12/17 Solas concord. Should I get a limited or Mod chamber? I am most likely going to get a MSD enhancer shortly after.
thanks guys. I have one more question. I bought the ski used, I am the third owner, the guy I bought it from bought it from the original owner who had it set up as a race ski. I'm not 100% sure but I think it might of had some port work done? The ski rips in the mid to top with the stock exhaust. The guy I bought it from does't know if its been ported or not. Any way for an easy check other then pulling the motor apart?
I have a buddy that has the same engine with no port work if i compare the two would I be able to see the difference?
I'm looking for a taller port right?
