Super Jet What are the benefits of a throttle wheel?
The only reason I use one is for adjustability I need with using a Kawi throttle cable.
OCD Solutions
Rentz, GA
I only paid $18 a piece for both mine.
I was able to modify my stock setups for the Kawi cables but the boysen manifold didn't have the same adjustability so I had to buy the drums. I'm sure I could have made something to work but the drums are way too simple and will make everything easier from this point forward.
Waternut
Customizing addict
Macon, GA
Alright, thanks guys. I just wasn't sure if it also moved the point of cable pull closer (less cable pull with more rotation) or further out (more cable pull).
OCD Solutions
Rentz, GA
i have been wondering the same thing. i had no clue people where running kawi cables either.
Yup, $29 bucks a pop versus $135 is a no brainer. If you spend a fraction of what you save on the billet wheel, you will still be under $50 and it will install and adjust in minutes.
Waternut
Customizing addict
Macon, GA
im glad this conversation happened, my throttle cable is starting to bind.
Yeah same here. I've been putting it off for a while but last time I connected it, I noticed that almost half of the cable was frayed. I just bought a new cable and wheel from jetmaniac.
