Yamaha 144mm
JetManiac got a deal of some NEW Yamaha wear ring / impeller housings from a shop that was closing, and we are passing the savings on to you.
Yamaha 144 pump -SuperJet, B1, VXR - WSM New $184. -this one only $99. SOLD
* Aluminum housing with black replaceable plastic liner
Yamaha 144 couch pump - SBT New $194. -this one only $95.
* Aluminum housing with white replaceable plastic liner
* Not threaded for 701 Raider, WR3, or other 144mm couch pump use
* Or add threaded inserts for SJ / Blaster use
*** see pics for discoloration corrosion on top
Yamaha 144mm couch pump - OEM New $477. -this one only $229.
* Aluminum housing with stainless liner
* Not threaded, for 701 Raider, WR3, Venture, or other 144 couch use
Yamaha 155mm pump
Yamaha 155mm couch pump - WSM New $205. -this one only $115.
*Aluminum housing with black replaceable plastic liner
* Not threaded for 1100 Raider, Venture 700/760/1100, XL700/760, GP1200, jet boat or other 155 non-PV couch use
* Or add threaded inserts for a/m hull 155 use.
Yamaha 155mm pump
