WDK Diablo hood liner repair?
I am having an issue with my Waterdawg Diablo hood.
The liner is starting to separate from the shell. I know this is a common problem.
How have people fixed this, and what has held up the best?
QJS
X-
GONE
Use Plexus MA310 Matt.
Chris.
I should add that I am in no way bitching about this hood.
I bought it used three years ago and I've been hard on it. I learned surf backflips and barrel rolls with it.
Jeff PM'd me about an hour ago offering to take care of this.
That's a pretty damn good indication of customer service. I won't take him up on the offer because the damage really isn't that bad, it's just the liner starting to come unglued. Also, I ride all winter and I don't want to miss out on any riding time.
StandupEd
Eddie would Tow
I like a mix of equall parts 404 and 403. 403 are the micro fibers that are intended for "gap filling". If you have it available I like 404,403,406 the best in equal parts. The scilica in 06 makes the batch thicken up and be less runny
grezzmky
Suckin paint fumes
Saint Louis MO
As always, never use anything that doesnt require a hardner, EVER. Id use something that is slow hardning so you can heat it up and get it to really run down in everywhere it can. If you try to heat som 5 min stuff it will kick to fast (and get REALLY hot). 3m panel bond is what I would use. 50bux a tube though. I glue quarter panels and door skins on with it everyday. Welding is for the birds.
DAG
Charlotte, NC
:eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2::eek2:
australia
matt i had the same prob with myn a while back fully ripped the linear out and found that the 2 were not keyed up it had to shiny surfaces so nothing will really bond to it so had to scuff it up to get a good surface then wet up some stripes of carbon fine weave and layed them in down the sides and around the air intakes as well so they werere fully blocked off then cut in breathers later and mixed up resin with filler/glue powder and smeared it in the front and around the latch area where they also meet
