Also just wondering where everyone else's holds are positioned in comparison to the 14" from the front that was mentioned here. I realise a lot will depend on rider height and pole length, but I'm just curious for my Square SJ.
Keep the pics coming everyone. I'm still not sure what direction my diamonds on the turf are going to run. I like seeing the different options.
Thanks guys!
First of all your from Toronto! never seen you before
Footholds like WCF are installed by the majority of people (whether they know it or not at the time) like EricFox did above.
The positioning of them is a preference. People who are taller or have a longer reach than the average dude are fine with putting the holds at the back of the hull where they fit perfectly.
Shorter riders may prefer to stuff them further up, so they can throw their weight that much more forward. If they are going more than a few inches (don't know exact) forward the exhaust tube will prevent a flush install, you can trim it the hold to get a few more inches.
Everyone is different and a lot of people don't know where they want them.
Edit: Also the turf diamonds run horizontal on the bottom and sides works best. The bottom turned the other way would have no benefit in traction.
Use a heat gun, make the turf soft the handle. Turf cuts pretty easily.
