- sunbury ,ohio
disconnect the pv motor from the harness , looking at the pv electrical coupler with the plastic lock at the 12 oclock position , hook batt pos to the right terminal, hook batt neg to the left term , touch a jumper from the left term to the bottom term for one to two secconds , upon removing the jumper .....the pv motor will cycle 105 degrees which is a lil more than 90 degrees when looking at it ! if it cycles its supposed to be good ! thats all it does the rest of the controlls are ignition controlled
