waveblaster nozzle boring ?
on a waveblaster-1 what can be expected from nozzle boring 2 mm , from reading i assume more holeshot -bottom end is it rally noticible ?, how much sacrifice on top end '' not that i really care '' ? ''what will it do to rpm - any change'' is it a worthwhile mod ? any input appreciated
Generally it provides better bottom with a slight drop in top end.
However, this all depends on your overall setup (motor & prop). If you are running a prop with an aggressive leading edge, you will not see as much gain like you would with a steeper prop.
I would start off with a smaller cone (similar results)...this way if you don't like it, just bolt back the original cone.
you lost me on smaller cone ''i thought the idea was to get a bigger hole ?? sorry i dont get it
romack991
homebrewed
Warsaw, IN
bigger water flow area
simplifed thinking is
water flow area = area of nozzle - area of cone
so shorter cone means more water can be pushed through it. similar effect as bigger nozzle.
ok , now i get it , shorter cone !! he said SMALLER thats what threw me , im still learnin ! i got it !:arms: end of thread !
SUPERTUNE
Race Gas Rules
Clearwater Fl.
Are you talking about a boring the nozzle with the stock Blaster impellor? with the bored nozzle the stock blaster prop is pretty weak...(bad hook up) Get a Solas 13/17 concord if your running a bored nozzle.
thats the 66e eng 120 hp the prop is a concord 14-18 cut back 3mm ,real nice mid to top end with real good hook up but 66e has no bottom brap ! more of a brrrap ! has a stock 144 gp800 nozzle , i have a spare nozz and might experiment with making it shorter after hearing these ideas . how much can i cut safely off ?
WaveDemon
Not Dead - Notable Member
Hell, Florida
don't make the nozzle shorter. you either bore the nozzle or get a shortened cone like a wet wolf cone.
here is what a shortend cone looks like if you don't know:
romack991
homebrewed
Warsaw, IN
i have a 13/15 cutback with bored nozzle and ww cone. i switched back to stock and lost some low end. ww cone is back on. it all depends on you enigne setup, prop, ski ect. I'd say experiment with them both.
