Tkmww
Tanner M.
- Jacksonville, Fl
I did a refoam with polystyrene but was wondering if there is something I can use to fill in the voids that it has. Small voids add up to lots of water.
either that, or if you reinforced, just install a versa plug inside the pump area.
Yep that sounds about right...hahaha.
I tried running without the plugs just to see if the water would drain out while i was moving...it did. After a ride you could hear the air bubbles as it was filling back up with water. So they were like mini-scuppers...hahaha.
