vista password help!
hhh
my parents just got a new computer with vista pre installed.
first time i booted it up it prompted a screen with guest and admin, well the admin requires a password that i did not set and have no other info that came with it other then the password hint is racing. its driving me nuts trying to figure it out and so far with no success. just wondering if someone can shed some light on this situation, i am a vista newbie.
thanks
ger87410
How did I get here?
Fort Worth
If you can't figure out the password, and you're convince there's a preset password on there, your only recourse is to contact the distributor, ie. Dell, and ask what the preset password is.
Usually preset admin passwords are blank when you install Windows XP. No experience here with Vista.
oxnard111
Creative RE Purchasing
there is software that will reset the vista password... you may be able to find a free version, but most are like $10.
usually you put them on a cd and make sure the computer boots to the CD. just follow the on screen instructions from there.
i have one version at my house... i'll see what it is when i get home tonight.
I use to have some dumb roommates that would mess with my computer and once a month would have to go in to their account and delete all the random :):):):) that was slowing my computer down. I am unsure if it works with vista but it worked with xp. Restart the computer and press F8 or F2 depending on what the choice is just keep tapping every 2 seconds both and the screen will come up (i just tested it on my vista) then start your computer in safe mode, i did not boot mine in safe mode cuz i dont have a password on here. Anyways continued, reboot in safe mode and see if it bypasses the login window, if it does, delete that password or change the password then restart your computer and see if you can get into it. Hope this helps....
ger87410
How did I get here?
Fort Worth
Chris, that method you just described won't work if the admin account has a password on it. Even on XP if the admin account has a password on it you'll get prompted in safe mode. I think it's the same for vista.
Using safe mode to bypass the admin password only worked in windows 98/95.
Ohio
Do the built in partition restore using the F11 key at boot. Its pretty quick....20 to 30 minutes if that. And then another 30 deleting crap and tweaking.
2lick
Brap!!!
Limerick, PA
can you login with the guest or another account, is so its real easy to get that password.
Let me know, if not and you have another computer on the network, its also not to hard to do.
let me know
2lick
Brap!!!
Limerick, PA
Actually come to think of it the easiest thing might be for you to just download a live CD version of ophcrack: http://ophcrack.sourceforge.net/
Burn it to a cd, put it in computer and boot from cd... will probably work, its not hard just point and click stuff
Lots of help on the net for it...
oxnard111
that is the same program i used to crack my vista password.
